Router keeps dropping out
Message 18 of 18
Yesterday (8th January) I had full fibre installed which all went well, however the new router keeps dropping out. What I mean by this all devices stay connected to the router but no internet is coming through. So any websites you load come up says the sever isn’t available or your device isn’t connected to the internet. This happens on all devices connected both through Ethernet and Wi-Fi. The router light says it’s connected to internet still but the only way to resolve this issue is to restart the router every time.
17 REPLIES 17
Message 1 of 18
@KeithFrench thank you for the support.
Phili
Message 2 of 18
V174 is very old now, it should be automatically updated soon to V208.
Message 3 of 18
@Anonymous please contact the full fibre team using the details below:
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Phili
Message 4 of 18
I had an engineer come round yesterday and he gave a replacement hub and it’s seems to have fixed the specific issue we were having with the internet dropping out. However, we have now got a different model, downgraded from a hub 3 to a hub 2 and we have noticed some devices aren’t quite as quick as they were (when the internet wasn’t dropping), which is a little disappointing as I’m now paying more than I did for full fibre. I also can’t put anything into the DMZ, every time it says invalid IP even though it’s valid, didn’t have this problem with the hub 3. Firmware version on the replacement hub 2 is SG4K100174.
Message 5 of 18
@Anonymous I have checked the case, and it has been assigned to the services team please allow the time frame of 2-3 working days for an update.
Phili
Message 6 of 18
@Anonymous thank you for confirming that, I will check if there is an update available.
Phili
Message 7 of 18
I contacted customer services on Saturday and after nearly 2 hours on chat was told a fault was found on the line and that it’s been forwarded to the case management team to investigate. I’m still currently waiting to hear back or have any sort of update.
Message 8 of 18
Phili
Message 9 of 18
Hi @Anonymous
Please can you answer my questions in my last post? Thank-you. Other than that, you will need to contact the Full Fibre Helpdesk on: 0345 172 0074.
Their opening hours are Monday-Friday 09:00 to 19:00, Saturday 09:00 to 18:00, Sunday: Closed.
You may not always be able to speak to someone on this number; they may send you a text message instead. If that is the case, the text will contain a link to start an online chat. On that chat, you can insist on speaking to a person, but there may be a delay before you are connected.
Message 10 of 18
@KeithFrench you can mention me if you need something.
Phili
Message 11 of 18
Yes I have powered down both the router and ONT for over an hour on Friday night and still regularly drops out.
Message 12 of 18
@Anonymous
Have you tried the 30 minute power down as suggested by @fr8ys earlier?
Message 13 of 18
Hi @Anonymous
When this happens, what is the state of the lights on the ONT? There are various ONTs that you might have, depending on who provided the Full Fibre, so please do not respond with "four green lights" or similar, as that will mean nothing to me. When it cuts out, what happens if you connect an Ethernet device to the ONT in place of the router? Does that work then?
Message 14 of 18
@Anonymous, the link I sent you shows the opening hours - they just drop everything at closing time, so allow a margin for queuing too!
Message 15 of 18
Thanks for the reply, I did try to contact live chat earlier and was sat in a queue for 20 minutes then got disconnected. I’ll have to try again tomorrow.
Message 16 of 18
Staff here do not have access to the full fibre systems to run diagnostics so you will need to phone them.
03451 720088
Before doing so though, power down both the Router and ONT box for at least 30 minutes to establish a new session.  This way you can advise the full fibre tram you have tried this.
When I updated it took a couple of days to settle down, but has been fine since. Hopefully yours will too.
Gliwmaeden2
Message 17 of 18
Try to reach support over the weekend by phone or Live Chat, @Anonymous.
Forum staff will not be back on here before Monday.
https://help-centre.talktalk.co.uk/Billing_and_Payments/Something_else/How_to_contact_TalkTalk_Broad...
