Strange setup eero, its not wireless
gripster
Message 14 of 14
So setup eero pro x 2 and waited for the huge increase to happen to my internet speeds.
Alas no, no one told me I had to use ethernet cables to reap the full fiber benefit. I'm a little dissapointed as now I have to tether to get good speeds. I spoke online with Leo from talktalk and he suggested I could get a 3rd eero pro to help with mesh in my flat. Is there a contact/process for this request.
Thanks in advance
Stv Dru
13 REPLIES 13
Message 1 of 14
OK, I've ordered the eero, it should be with you within a couple of days
Message 2 of 14
thank you i would very much appreciate that
Stv Dru
Message 3 of 14
I  can send another eero to test with but I think it's unlikely to make much difference as signal strength looks fine throughout your home.
Message 4 of 14
Yes they are. I was told by online chat Leo that I could request a further eero 6 pro to place in my lounge, so that's all I'm trying to do.
Stv Dru
Message 5 of 14
OK thanks. Are the devices that you are running the speed tests on capable of wireless speeds higher than that?
Message 6 of 14
Sorry Chris I kept reading the bottom post as latest
Wireless speeds in my lounge smart tv pc 300 down 90 up
Where I can use ethernet in bedroom on ps5 and computer 390 down 90 up not the 900 fft
Stv Dru
Message 7 of 14
You have done what I asked, just wondering what speeds you are actually getting over wifi. If you're throughput speeds are low we can see if there's anything that we can do
gripster
Message 8 of 14
Ok I thought I had done as you asked, I have no idea what else to do, this is beyond frustrating
Stv Dru
Message 9 of 14
OK thanks. What speeds do you get over wifi?
gripster
Message 10 of 14
Updated thanks
Stv Dru
Message 11 of 14
Thanks for updating but could you add the account number to the private notes section of your community profile
gripster
Message 12 of 14
Updated thanks
Stv Dru
Chris-TalkTalk
Message 13 of 14
Hi gripster,
  • Name
  • Telephone number
  • Alternative contact number
