BT Digital voice adapter.
digby2
Message 3 of 3
I have Fibre 35 Internet and, looking forward when I am converted to VOIP in the future, I have the following question:
My router and DECT phone base unit are some distance apart and it would suit me better to use the BT ATA adapter (V2  X16-G90 ) which I understand has a wireless connection to the router, via my TP range extender.
Will this setup work with the TalkTalk VOIP system?
Message 1 of 3
HI @digby2
@kanya-TT has asked me to help you. Alas, without one of those ATAs to test with, I can't answer your question. It should be OK, if you have the Sagemcom Wi-Fi Hub 3, inasmuch as the WPS connection should work. Beyond that, however, I can't say. The Wi-Fi Hub 3 has a simple phone port on the back to connect your DECT base station to. You can easily get a telephone extension cable if required. It is hoped that the Hub 3 will replace the eeros, which do not support WPS at all, but they do come with a Grandstream ATA, but that connects to the eero via an Ethernet cable, not Wi-Fi.
kanya-TT
Message 2 of 3
Hey there, @KeithFrench. Do you mind assisting with this one.
Kanya
