Weak wifi signal eero 6
21-02-2025 04:34 PM - edited 21-02-2025 04:40 PM
Message 4 of 4
I've had FTTP 150 with TalkTalk for a while now, via eero 6. The wifi signal in one of the bedrooms upstairs has always been awful but it has never been an issue until now - because I need to use the room as a study.
I live in a regular 4 bedroom house and the bedroom with trouble is not far away - direct distance (through the walls) is less than 5 metres .
I note that we never had this problem with our old FTTC Talktalk huawei router.
What can I do?
Labels:
- Labels:
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
3 REPLIES 3
on 21-02-2025 10:06 PM
Message 1 of 4
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2025 04:56 PM
Message 2 of 4
Thanks Keith, yes please send it over
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-02-2025 04:42 PM
Message 3 of 4
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- PC WiFi slow, but devices are OK, (Not a Talktalk problem?!?!). in Broadband
- Eero 6 and Goggle nest in Full Fibre
- Web page incorrect eero info in Broadband
- Fibre 65 lagging, discconections, slowing down, throttling? in Broadband
- Facetime calls not connecting / going through when connected to EERO in Fibre
