on 08-06-2024 01:46 PM
I’d like security cameras fitting in my garden , Wi-Fi ones , what is the distance my Wi-Fi will cover , and is there something I can add to make it better.
on 08-06-2024 02:46 PM
Hi @SHIRLEYn81! There are so many variables to consider that no one in their right mind would give you an answer.
I would try one first and see what happened, or even turn your mobile onto WiFi rather than sim and see what reception was like where you plan to site the camera.
WiFi extenders are quite reasonably priced if the signal from the router is inadequate.
