Wifi Hub
Werepaws
Message 10 of 10
My talk talk wifi hub started acting up. The wifi would be connected but the device would stop responding having to restart wifi on the device.
turning the router off for a reboot. It would take ages to reboot and when it did. All the settings forgotten. Incl wifi passwords defaulting and admin password
last time i rebooted it. It took 4 hours to come back to a useable state
what's more is I have noticed from January 11 until i bought a brand new that isn't talk ralk router ( im gfast so have the extra sagam modem)  it re established talking to the dimplex cloud again. that controller is plugged in by ethernet and allows the storage heaters etc all communicate
I spoke to talk talk about rhe issue. They came back with the router seemed healthy and fine and apparently it was the modem that was the issue and they said they had requested a new modem
not heard anything about that either
when the contract is up. Soon. Im moving back to sky.
then I can send the junk router back as I don't need a replacement now
modem seems just fine too i believe
tplink archer AXE75 in place of talk talk super hub wifi
at least it works and properly
9 REPLIES 9
Message 1 of 10
Hi Wolfy
That's great, thank you for letting me know 🙂
I hope the new router resolves the issues on your dads connection too.
Debbie 🙂
Message 2 of 10
Hi Debbie. Received the new router today
I checked the differences between the power supplies and the old power supply is dying. Its not able to deliver a stable current amperage to the router amd was causing it to squeel slightly
the new router doesn't do that and nor does the old router when using the newer power supply on the old router
and then tested with a meter too!
so found the problem there!  Will send the old one back with the recycling bag thing.
not sure on my Dad yet. But will find out soon im sure!
thanks for your help again!
will let you know how my dad gets on!
take care for now!
Wolfy
Message 3 of 10
Hi @Werepaws
Thank you for updating the details.
I have ordered both routers, please allow 24-48hrs for this to arrive.
Please let me know how  you get on.
Message 4 of 10
Thanks Debbie. I have added my dad's landline and name to the private notes
thank you again for your help.
i can send my old one back for diagnostics so you guys can see what is wrong with it. If its a firmware problem or device is rotting with bit rot
to be honest ive not had any issues with talk talk to be honest. Service has always been top notch
the only time i had an outage was was when a fire happened at a telephone exchange near by which hosted alot of backbone haul lines
that was not in your control
speeds have been great always get 30mbit up and 155mbit down
you guys always get things sorted in the end if a phone call or here
so I can not grumble much
I think i just let the thing get to me because it knocks out all the smart devices on the network when it happened and then to get all the configuration back and if it doesn't go right you then have to re program all the smart bulbs to connect and that is a pain because you have to turn the bulbs on and off 5 to 6 times to enter pairing mode
then when it was taking hours to come back up ( had an electrical re wire recently so it had to go off ) then a test a week later
then a new smart meter install
so yeah the frustration level reached a point of arghh
Wolfy
Message 5 of 10
Hi @Werepaws
I can send you a new router today. Would it be ok if you added your dads name and landline number to the Private Notes section of your Community Profile, I can then send a router to your dad too.
If you did decide to leave TT then the router would need to be returned.
Message 6 of 10
You can look into them
seems alot of companies incl sky are focusing on full fibre which isn't available yet in my area. Its happening in stages and likely looking st 2026
my talk talk services come under renewal  around the start of july this year
so still a few months away
my dad recently renewed his talk talk services but they didn't send a new router his is very old huawai one. I had no idea he did that until a couple days ago when he asked me to install his new android tv box from your guys.
so if you do end up issuing me a new wifi hub. And o me sending my defective one back. Id prefer him to have the wifi hub for his service ( which isn't gfast just your ftc vdsl service)
as I now use a dedicated router connected to the wan port of the sagam gfast enabled modem
but yes going back to that. The live chat fella said my modem was faulty.  But I don't think it is but obviously i don't run tests to see
but the router wifi hub is definitely faulty which is why i had to replace it
Thanks!
Message 7 of 10
Hi @Werepaws
Thank you.
Would you like us to take a look at this issues you are experiencing or would you prefer to transfer your services away?
Message 8 of 10
Hi thanks for responding
I have updated my profile with the information you asked for
regards
Wolfy
Message 9 of 10
  • Name
  • Telephone number or Account number
  • Alternative contact number
