Wifi keeps dropping out
msbutterfly00
Message 9 of 9
I joined TalkTalk in April and every day the wifi drops out. I can watch TV and it switches off. I have tested it and followed the instructions constantly to test the line and switch everything off for 20 minutes and re connect - but it keeps happening. Every day.
8 REPLIES 8
Message 1 of 9
Hi @msbutterfly00
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 2 of 9
Oh yes please Keith. Greatly appreciate any advice.
Thank you 😊
Message 3 of 9
Hi @msbutterfly00
Would you like my help then?
Message 4 of 9
Hello
Yes it keeps happening every day. Time of day differs. The router is FAST F5364-3.T8
Everything is wireless.
I would have to look at the router light when it happens as usually in another room.
The signal strength is good.
Message 5 of 9
Hi @Donna2569
I cannot help you on someone else's thread. If you would like to create your own one & @mention me into it, I would be able to help you from there. It could well be WiFi interference or various other issues. I can help check this out, never buy extra hardware when you may not need to.
To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
Message 6 of 9
Hi keith
we too suffer from this - we have an eero 6 and since installation it invariably drops out on some devises although always shows strong signal strength and is always fine when you run a health check?!  We were thinking of adding an extender (£99) to see if this helps but after reading your comments am wondering if there is another issue that may be causing the problem?
Message 7 of 9
How are you getting on?
Message 8 of 9
Hi @msbutterfly00
Which make/model of router do you have?
