eero help
tinbin
Chat Champion
Message 9 of 9
 i have just  upgraded my broadband to  fibre150
 i have just got my  eero router...   i would like to no the eero app  how much  phone data
goes it use  on my phone  because i dont  have a lot of data ? on my phone  can the eero app use  wifi  ?
thanks
craig
8 REPLIES 8
Message 1 of 9
Please let us know if you need any further assistance.
tinbin
Chat Champion
Message 2 of 9
BIG thanks   for all your help...    think i got it now
craig
Message 3 of 9
The eero Support Hub is your go-to resource for information, guides and Community support.
I've included a selection of the guides below.  The eero has two Ethernet port sockets so to connect it to the Internet using your existing service you'd connect one eero port to one of the yellow Ethernet sockets on your existing router. NB this is just for the set up process not the final install as that will require you to disconnect your existing router and connect the eero to the ONT that's going to be installed to bring your Full Fibre service in to the home.
As part of the eero set up you can choose your Wi-Fi Network name and Wi-Fi password.  To make the switch over easy you can use the existing router Wi-Fi Network name and Wi-Fi password. But be aware that using the eero and the existing router Wi-Fi at the same time with the same name is not recommended. When you cease to use your existing router then the eero will be set up to take over the device Wi-Fi connections. i.e. a seamless switch over.
Select here:
eero Support Hub
eero 6 and eero Pro 6 Help
eero - Setting up your eero
 eero app
 Using eero advanced features
 Managing eero profiles and devices
eero network and light status
eero light too bright?
eero - Fixing your eero network when offline
tinbin
Chat Champion
Message 4 of 9
ok thanks
also   internet cable lead  plug it in the wall   how do connect it to pc   another lead to back of pc ?
Message 5 of 9
I set mine up in advance so it was ready for the switch over.
tinbin
Chat Champion
Message 6 of 9
   i have just got my eero  can i    use it  now... or do i have to wait  for talktalk to  connect my 150fibre   am on 65fibre at the moment
thanks
craig
tinbin
Chat Champion
Message 7 of 9
nice one  thanks....   that good to know
craig
Gondola
Message 8 of 9
When set up and in normal use the eero app will use the TalkTalk broadband connection via Wi-Fi. If you're at all concerned you can disable mobile data in the app management settings on the 'phone.
