eero
pingpal6
Message 3 of 3
eero not enough lan ports
Message 1 of 3
Good morning,
Need to connect multiple devices to a wired network? Investing in a network switch will allow you to connect several devices to your router via a wired connection, ensuring that every device is provided a seamless high-speed connection. You can use any network switch you like, but we’d recommend a gigabit network switch, which can handle speeds of up to 1000 Mbps.
Message 2 of 3
No, you're right. If you need more, buy an ethernet switch.
