fibre to cabinet
mikebowley
Message 3 of 3
I have FTCC  and 3 phones attached  to router via master box. If I upgrade to FTTP, can I then use the phone network  by plugging into VOIP socket on new router?
Message 1 of 3
Thanks @KeithFrench
Michelle 🙂
Message 2 of 3
Generally, depending on the Digital Voice solution that you are provided with, if these are three DECT handsets using the same base station, there won't be a problem. However, if they are separate phones connected via internal wiring (which would need to be changed a bit), it could be an issue depending on their combined REN value.
