on 22-12-2023 03:43 PM
I have FTCC and 3 phones attached to router via master box. If I upgrade to FTTP, can I then use the phone network by plugging into VOIP socket on new router?
on 27-12-2023 06:22 AM
on 22-12-2023 10:25 PM
Generally, depending on the Digital Voice solution that you are provided with, if these are three DECT handsets using the same base station, there won't be a problem. However, if they are separate phones connected via internal wiring (which would need to be changed a bit), it could be an issue depending on their combined REN value.
