how to connect full fibre to a dsl openreach modem
killerme
Message 9 of 9
I have full fibre which comes from the wall as an rj45 cable.  I have an asus rx router so I want to put an openreach modem in between.  Unfortunately the modem only has an rj11 port as dsl.  How can I get round this? (I'm sure I solved this problem before when I tested it some months ago but no idea how I did it.)
8 REPLIES 8
Message 1 of 9
Thanks for the update 🙂
killerme
Message 2 of 9
great Michelle. once I knew that I didn't need a modem I could transfer everything fine. all is working well now. I moved to an asus rx ax58U which gave me full cover across the house and an option to mesh further extension into the garden. cheers
Message 3 of 9
Good morning,
How are you getting on?
Message 4 of 9
Have a look at this:-
https://community.talktalk.co.uk/t5/Articles/How-Full-Fibre-is-installed/ta-p/2555166
killerme
Message 5 of 9
 wow amazing. thanks ever so much Keith. really appreciated. I've been trying to figure this out for hours
Message 6 of 9
If you have full fibre it is different. It terminates in an ONT and a router (TalkTalk router or 3rd party) connects from its Ethernet WAN port to the Ethernet port on the ONT. That is it, no modem at all.
killerme
Message 7 of 9
appreciated - but then I would have no modem?
Message 8 of 9
They are totally incompatible. You should connect the fibre from the ONT to an Ethernet WAN port on your Asus if it has one.
