internet dropping off
g16jyn
Message 17 of 17
Hi since the 13th feb my internet keeps dropping off, i spent hours chatting on twitter yesterday and logged in to my router settings and it hasnt fixed the issue, the white light stays on the router even though there is no internet connection.
16 REPLIES 16
Message 1 of 17
Hi @g16jyn
I'm so glad to hear that this fault has been resolved 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 17
That's great news g16jyn, thanks for letting us know
g16jyn
Message 3 of 17
Hi Debbie,
Yes i received it on Saturday and it seems to have fixed the issue.
Many thanks for your help!
Message 4 of 17
Message 5 of 17
Hi g16jyn
Thanks again.
Debbie 🙂
Message 6 of 17
Hi Debbie,
Yes that would be great, thank you so much for your help,
Message 7 of 17
Hi g16jyn
I will need to swap the router to a Sagemcom WIFI hub to resolve this issue. Are you happy for me to arrange this?
Message 8 of 17
Hi g16jyn
I'm really sorry about this.
I have escalated this to our Devices Team and I will post back here as soon as I have further information.
Message 9 of 17
Thank you so much for your help with this it really is appreciated!
Message 10 of 17
OK V1.08 needs downgrading before looking at anything else.  I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
Message 11 of 17
yes it is the v1.08.
Here is a copy of the user log, this is just from today;
1981-01-01 00:00:13 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-18 16:23:55 [Critical][Run-Log] Time synchronized successfully, uptime:[58s], src:[3], app:[sntp], pid:[3023]
2024-02-18 16:24:19 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 16:24:23 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T16:24:23.659Z
2024-02-18 16:29:02 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-18 16:30:14 [Critical][Run-Log] Time synchronized successfully, uptime:[61s], src:[3], app:[sntp], pid:[3081]
2024-02-18 16:30:36 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 16:30:41 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T16:30:41.751Z
2024-02-18 18:34:32 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-18 18:35:43 [Critical][Run-Log] Time synchronized successfully, uptime:[59s], src:[3], app:[sntp], pid:[3022]
2024-02-18 18:36:06 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 18:36:11 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T18:36:11.346Z
2024-02-18 19:38:12 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-18 19:39:21 [Critical][Run-Log] Time synchronized successfully, uptime:[57s], src:[3], app:[sntp], pid:[3020]
2024-02-18 19:39:45 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 19:39:51 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:300,PeriodicInformTime:2024-02-18T19:39:51.279Z
2024-02-18 19:42:15 [Critical][Config-Log] Terminal:WEB(192.168.1.12),Result:Fail,Type:Login,Username:admin
2024-02-18 19:42:43 [Critical][Config-Log] Terminal:WEB(192.168.1.12),Result:Success,Type:Login,Username:admin
2024-02-18 19:44:51 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 19:44:51 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T19:44:51.850Z
2024-02-18 19:45:46 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-18 19:46:58 [Critical][Run-Log] Time synchronized successfully, uptime:[60s], src:[3], app:[sntp], pid:[3033]
2024-02-18 19:47:20 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 19:47:25 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T19:47:25.811Z
2024-02-18 19:51:35 [Critical][Config-Log] Terminal:WEB(192.168.1.12),Result:Success,Type:Login,Username:admin
2024-02-18 19:52:49 [Critical][Run-Log] Time synchronized successfully, uptime:[61s], src:[3], app:[sntp], pid:[3117]
2024-02-18 19:53:10 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestUsername:userid,ConnectionRequestPassword:-
2024-02-18 19:53:15 [Critical][Config-Log] Terminal:ACS(62.24.243.161),Result:Success,Type:Set,InternetGatewayDevice.ManagementServer:,PeriodicInformEnable:1,PeriodicInformInterval:86400,PeriodicInformTime:2024-02-18T19:53:15.724Z
2024-02-18 19:54:41 [Critical][Config-Log] Terminal:WEB(192.168.1.12),Result:Success,Type:Login,Username:admin
Message 12 of 17
The router to the internet is fine then. However, what firmware version is on the router, is it V1.08 by any chance:-
Dashboard > See Internet Settings > Manage advanced settings > System Info > Device Information
Please can you get me (copy & paste) the user log from the router for the time period of the devices dropping out:-
Dashboard > See Internet Settings > Manage advanced settings > Advance Configuration > Maintenance Diagnostics > User Log
Message 13 of 17
Hi, yes as soon is i connect more than one device to the router i loose all internet access to all devices, i have the Huawei DG8041W router, even though the internet dops the white light still stays on the router.
Message 14 of 17
I am still trying to understand do you mean that you are disconnected from the router's  WiFi signal?
OK, which make/model of router are you using?
Message 15 of 17
its my laptop and as soon as i connect my mobile or any other device to the WIFI eg mobile or playstation  the internet cuts off, as soon as i disconnect the other devices the signal comes back on again.
Message 16 of 17
By the sounds of it, the router is connected to the internet, but maybe some devices might be connected to the router, but have no internet access. Does this affect all devices or just a few & what sort of devices are they?
