Home Phone
Caller display not working-again
popboffy1
Message 18 of 18
Same fault , can't grumble too much, I've had 43 days of uninterrupted caller display without a problem, but here we go again it took 17 days to sort last time so I'm not holding my breath.
17 REPLIES 17
Message 1 of 18
Many Thanks
Message 2 of 18
Ok thanks for confirming and I hope everything goes well with your new ISP.
popboffy1
Message 3 of 18
No Michelle, it would be a complete waste of their time as I won't be with Talk Talk for that much longer.
Message 4 of 18
I'm sorry to hear this. Would you like us to pass the Caller Display issue over to our Faults Escalation Team?
popboffy1
Message 5 of 18
Good morning Michelle,
Unfortunately the "Caller ID" hasn't been working since we spoke last, but I wouldn't waste time on it, the initial test run on what I spoke of earlier was very favourable gave me speeds of (34 mb download and 7.10 mb upload) comared to (10.6 and 0.35) so it's a no brainer, but thank you for your efforts in trying to sort out.
Best Regards,
Mike Baugh.
Message 6 of 18
How are you getting on?
Message 7 of 18
Thanks for confirming. Have we also tried testing the router at the test socket to see how the speed compares?
Ok, no problem. We'll check back in with you on Monday morning to see how you're getting on.
Message 8 of 18
I think best leave it until I get the results on the weekend re: my previous message, I'll test "caller display" later when the wife gets up and let you know, we can leave it then whatever the outcome till Monday when I'll message you.
popboffy1
Message 9 of 18
Hi again Michelle, tried sending message at 07.07 and 07.29, yes you’ve guessed it, down again, I do appreciate your efforts in sorting out this continuous problem, you must feel like the captain of a sinking ship I don’t envy you, Just to keep you informed I’m testing out an external aerial on the weekend and if I get any faster speeds than at present (which won’t be hard) I’ll be transferring my telephone system over to VOiP, can’t be any worse than at present.
Message 10 of 18
I'm sorry to hear this. I've run a test on your line now which is clear, however I can see some re-connections on the line. Do you have an alternative router that you can test with? If not then we can send a replacement router for testing purposes to rule this out.
popboffy1
Message 11 of 18
Hi Michelle, tried to reply to your last message but unfortunately my internet has been down again all morning, I keep on restarting the router and it will sometimes work for a couple of minutes before crashing again, I will try the “caller ID” later and advise.
Message 12 of 18
How are you getting on? Has there been any change?
Message 13 of 18
Hello again,
Thanks for the update. I'll check back with you in the morning to see if their is any change.
popboffy1
Message 14 of 18
OK done as requested will wait till midday to re-instate. Thanks.
Message 15 of 18
I'm sorry to hear this. Would you like us to take a look at your connection too?
popboffy1
Message 16 of 18
Internet working spoadically all morning will try and remove when I'm able to.
Message 17 of 18
I'm really sorry to hear this. Just before I pass this over to our Faults Escalation team, could you try removing the Caller Display service in your My Account please, wait 4hrs then try re-adding this again. If it is still not working following this then I'll escalate this straight over.
