Home Phone
Callsafe screened calls and voicemail
hughg
Chat Champion
Message 6 of 6
How do callsafe screened call and voicemail co-exist? i.e. does screened caller get to leave a message?
5 REPLIES 5
Message 1 of 6
Hi @hughg well worth it, costs nothing. Be aware that you cannot download nor upload list of approved and barred numbers.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 2 of 6
OK, I now have a good idea how CallSafe operates. I will activate it and close this post as solved.
Message 3 of 6
Hi @hughg I can only speak for my setup.
Approved call go straight through and answerphone picks up after about 10 rings
Blocked calls are never heard.
Screened calls either ring or are picked up by answer phone, don't know how many rings because I'm either out or pickup after 5 or 6 rings.
Don't know about system hanging up, never tried.
Caller ID displays incoming number unless id hidden.
I hope this helps I have found callsafe to be excellent and have not had a landline unwanted call in 4 or 5 years.
hughg
Chat Champion
Message 4 of 6
Thank you for reply.
Currently my phone voicemail cuts in after 5 rings. There would be no problem with approved callers (message could be left), or blocked (wouldn't ring}. From what you say the screened caller message from CallSafe would be recorded.
How long before the system hangs up when you don't accept or reject?
What caller id shows with the screened call message?
Divsec
Message 5 of 6
Hi @hughg my answerphone is phone rather than Talktalk based and I do get the name of unknown callers and a full message from known callers.
