7 hours ago
How do callsafe screened call and voicemail co-exist? i.e. does screened caller get to leave a message?
Answered! Go to Solution.
2 hours ago
Hi @hughg well worth it, costs nothing. Be aware that you cannot download nor upload list of approved and barred numbers.
2 hours ago
OK, I now have a good idea how CallSafe operates. I will activate it and close this post as solved.
2 hours ago
Hi @hughg I can only speak for my setup.
Approved call go straight through and answerphone picks up after about 10 rings
Blocked calls are never heard.
Screened calls either ring or are picked up by answer phone, don't know how many rings because I'm either out or pickup after 5 or 6 rings.
Don't know about system hanging up, never tried.
Caller ID displays incoming number unless id hidden.
I hope this helps I have found callsafe to be excellent and have not had a landline unwanted call in 4 or 5 years.
3 hours ago
Thank you for reply.
Currently my phone voicemail cuts in after 5 rings. There would be no problem with approved callers (message could be left), or blocked (wouldn't ring}. From what you say the screened caller message from CallSafe would be recorded.
How long before the system hangs up when you don't accept or reject?
What caller id shows with the screened call message?
3 hours ago
Hi @hughg my answerphone is phone rather than Talktalk based and I do get the name of unknown callers and a full message from known callers.
