on 26-10-2025 10:57 AM
I have just received an eero router but it has no connection for my landline phone. How do I connect my phone? Should some sort of adapter have been sent?
on 26-10-2025 12:36 PM
But did you specify VOIP with the upgrade, @Debs52 ?
Have you tried using the old router? Was it a Hub 2 or Hub3?
They are more usually sending out HUB 3 (Sagemcom) now.
An Eero would need a digital voice adaptor for using the phone but check on Chat today or call 03451 720074 after 9am Monday to Saturday. There's not a lot that forum staff can do regarding anything connected with Full Fibre issues, so follow up as above rather than waiting for their reply during the week.
on 26-10-2025 11:52 AM
Yes, I was already on voip, the old router I had the phone plugged in the back. I upgraded to 500, they sent new router but it has nowhere to plug the phone in to.
on 26-10-2025 11:49 AM
You mean for VOIP? Did you order VOIP with the full fibre at the time, @Debs52?
