Home Phone
Digital switchover - will I not be able to use my landline phone after the end of 2025
Sweepy1
Message 4 of 4
Advice please
3 REPLIES 3
siphosethu-TT
Message 1 of 4
Thank you @fr8ys, appreciate the help.
Message 2 of 4
If you wish to keep a landline, you should be able to do so at switchover.
You will need to be specific that you wish to retain your phone and phone number.
The difference will be that your phone will plug directly into your router or an adaptor that will be supplied. Your existing line that it currently plugs into will no longer work.
Hope this helps.
siphosethu-TT
Message 3 of 4
Hi there @Sweepy1, please contact our loyalty team so they can advise you on how you can move forward if you wish to keep your landline services.
03451720088
Monday - Friday 9am - 7pm ; Saturday - 9am - 6pm ; Sunday - Closed
