Home Phone
Landline Phone Problem
Jimpy2
Message 29 of 29
I have full fibre 150 with a grandstream for VOIP on my landline phone, my landline phones are a Quad set of BT 8610 phones with a Answer Phone on one base unit which is plugged into the Grandstream, the Grandstream is then plugged directly into a eero unit, all worked OK at start but recently when I get a incoming call not all the phones ring sometimes only 2 then at times 3 and on rare occasions all 4 will ring i have swopped the phones over to different base units but it doesn't seem to make any difference, the phones worked perfectly on incoming and outgoing calls before I went onto full fibre.
Jimpy, Staffordshire
28 REPLIES 28
Jimpy2
Message 21 of 29
Hi Michelle,  the unit plugged into the dva is the answer machine unit (Main base unit) and yes the problem is the same across all phones / base units after a reset, the dva seems to reset correctly ie within the correct time.
Message 22 of 29
Good morning,
When you reset the Digital Voice Aadapter does it start working again? Does the main phone connected to the DVA experience this too or just the additional handsets?
Message 23 of 29
That's an interesting question and I'm not sure. Mine supports three, no problem. The fact that your issue seems sporadic is odd.
Jimpy2
Message 24 of 29
Yes do understand ferguson that the hand sets have nothing to do with TT but haven't got another set to try and don't understand what could make the phones not to ring, have tried resetting the Grandstream a few times but just get same results, is there a limit how many hand sets the Grandstream can handle?
Message 25 of 29
OK, but I do wonder if the support team can help with third-party equipment such as handsets, let's see what they they have to say.
Jimpy2
Message 26 of 29
All the hand sets show batterys fully charged and ok
Jimpy2
Message 27 of 29
Hi Ferguson,
Yes my first thoughts so replaced the batterys  in all the  hand sets, but can't really say the hand sets are OK but I have changed them about into different bases and still no joy
Message 28 of 29
Is it possible that the connection between the handsets is at fault, maybe some batteries need checking?
