Home Phone
Landline false ring every 30 minutes
Andy171
Message 17 of 17
Since fibre was installed our phone starts to ring every 30 seconds then stops. Can talk talk create a fix for this?
16 REPLIES 16
Message 1 of 17
I'm really glad to hear this 🙂
Michelle 🙂
Andy171
Message 2 of 17
Hello Michelle, the issue is resolved. Many thanks
Message 3 of 17
Morning Andy,
I've not received an update as yet. If I don't hear anymore by later this morning then I will chase this.
Message 4 of 17
Hi Andy,
No problem, I should hopefully know more today.
Andy171
Message 5 of 17
Thanks Michelle, we look forward to the resolution.
Andy
Message 6 of 17
Hi Andy,
I've passed this over to our Faults Escalation Team now and have asked them to apply the fix for this particular issue. I will post back here as soon as I receive confirmation that this has been completed.
Andy171
Message 7 of 17
With eero and Grandstream we had no landline at all. Several phone calls and one very long live chat, unplug this and that, restarts, reboots,,,nothing. So we are now on the router where we at least have a landline, which is essential, we can not be without it. Therefore we have to stay with this router but would like the annoying false ring sorting out. Please tell your colleagues not to suggest eero again, my nerves will not take it. Thanks
Message 8 of 17
Sorry, just to confirm, You're using the sagemcom router and not the eero with grandstream digital voice adapter?
Message 9 of 17
Hi Andy171,
OK, I'll pass this over to our Network team and ask them to take a look. We'll let you know when we receive an update or they may contact you directly
Andy171
Message 10 of 17
It's a very brief ring, stops almost immediately after it starts. We don't have another phone available. I read another post where someone called it a 'missed' call, same as us every thirty minutes. Also it's always 23 and 53 minutes past the hour if that helps.
Message 11 of 17
OK thanks. How long does the phone ring for aproximately? Do you have another telephone that you can test with?
Andy171
Message 12 of 17
I can't tell, the label has come off. It's a retro dial type with a traditional bell ring.
Message 13 of 17
Hi Andy,
What is the make and model of your telephone?
Andy171
Message 14 of 17
The phone is plugged into the talk talk router. Phone numbers are updated in profile, thanks
Message 15 of 17
Hi Andy,
Just to confirm, are you using VOIP on the Wifi Hub 2 router please?
  • Name
  • TalkTalk Telephone number
  • Alternative contact number
Message 16 of 17
Yes they can.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
