on 17-02-2026 10:19 AM
Good morning, my landline has developed a problem, it has a lot of background noise and is difficult to hear someone talking, they also can't hear me very well as voices fade in and out. Could someone please run some checks on my line to see what the problem is. Thank you.
on 17-02-2026 12:47 PM
Do you want me to disconnect the filter with the router and phone plugged into it? I won't be able to reply to you until i plug them back in. If so, for how long?
on 17-02-2026 12:43 PM
Please can you remove everything that is connected to your phone socket?
Were you able to complete the check?
on 17-02-2026 12:41 PM
Yes, all handsets are affected.
on 17-02-2026 12:40 PM
Are all of your cordless telephone handsets affected?
on 17-02-2026 12:37 PM
A cordless phone, i have also tried a corded phone and a different cordless one. The noise is there on all phones I've tried.
on 17-02-2026 12:34 PM
Which type of telephone do you currently have connected?
Corded or
Cordless
on 17-02-2026 12:33 PM
One socket, the main one.
on 17-02-2026 12:26 PM
Thank you, how many sockets are you currently using?
on 17-02-2026 12:24 PM
No, it doesn't look damaged, just old.
on 17-02-2026 12:22 PM
Is your master telephone socket showing any visible signs of damage?
on 17-02-2026 12:18 PM
It's the first one pictured in the link, Non nte, with no test socket, it's been there since the 1980's
17-02-2026 12:04 PM - edited 17-02-2026 12:09 PM
I need to find out what type of master, or main, telephone socket you have so I can give the correct troubleshooting advice.
The master socket will be a white box on a wall, and is where the telephone line connects into your house from outside.
Please browse to https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432 - this page shows you images of the different socket types so you can identify which you have.
Can you confirm what type of master socket you have please?
NTE 5C mk4
NTE 5C
NTE 5
FTTC
NTE 2000
Non-NTE
No Socket Provisioned
Unable to identify due to accessibility needs
on 17-02-2026 12:03 PM
There is still a loud buzzing noise and interference on the line.
on 17-02-2026 11:59 AM
Please try to use your telephone and confirm if the phone service is working okay.
Is the phone service now working
on 17-02-2026 11:57 AM
The phone is connected to the main socket, the noise is still there.
on 17-02-2026 11:48 AM
Please disconnect your telephone from the extension socket and connect it directly to the main master socket. This will help us check if the main socket is working properly.
To do this, unplug the cable from the extension socket, locate the main socket (usually built into the wall), and securely connect your telephone to it. Once connected, please check if you can cannot hear noise in the calls and your service working as expected.
Have you managed to do that?
on 17-02-2026 11:47 AM
It's plugged in to the main socket.
on 17-02-2026 11:42 AM
Is your telephone currently connected to the extension socket?
In other words, is it plugged into the socket that's separate from the main wall socket?
on 17-02-2026 11:40 AM
There are two, the problem is the same noise with both of them.
on 17-02-2026 11:36 AM
Do you have more than one telephone wall socket in your home?
