on 13-09-2025 05:17 PM
I have a fibre system and all devices are working effectively except for landline phone. There is a dial tone, and you can phone other numbers and they ring out and you can receive incoming rings but in all instances there is no voice. This problem I have had for the last 3 days. All suggestions welcome, please. Thanks
on 15-09-2025 09:37 AM
on 14-09-2025 03:20 PM
Pleased the old off and on trick worked.
on 14-09-2025 02:04 PM
Many thanks for your advice.
I rebooted the Grandstream, without rebooting the router, and it solved my problem.
Thanks again.
on 13-09-2025 06:23 PM
Is this a full fibre contract?
Which router do you have?
What have you tried to rectify this? Rebooting the router and / grandstream (if you have one)?
