NEED PHONE LINE CHECKED - CALL SAFE PROBLEM
on 02-12-2024 07:57 PM
Message 18 of 18
Hello....
I've used CALL SAFE on my landline for a long time without problem.
When someone 'unknown' calls, they have to identify themselves. I can then accept or reject.
However, on a recent call I was expecting, I accepted but heard nothing more at the caller's end.
I've subsequenly found outby email that all they heard after stating their name was my phone 'ringing out'!!
I put their number in my 'approved' list and emailed them asking for a repeat call a couple of days later. This was done and I answered immediately but all I heard myself this time was a whining noise!
The call was from a mobile phone but again, I've never experienced any problem with landline or mobile callers in the past.
Could an OCE check my line as soon as possible for faults + Call Safe?
Many thanks
Labels:
- Labels:
Callsafe
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
17 REPLIES 17
on 12-12-2024 07:01 AM
Message 1 of 18
Ok thank you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-12-2024 04:57 PM
Message 2 of 18
Hello Chris.
Thanks for the info....If the probem persists I'll let you know. Thanks for at least trying something...
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-12-2024 08:07 AM
Message 3 of 18
Hi kwilsaint,
I resynced a backend system which often resolves issues with select services. Please let me know how you get on with a CallSafe call when you get one
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-12-2024 06:44 PM
Message 4 of 18
@kwilsaint wrote:
Call Safe has never caused me problems in all the time I've used this excellent TalkTalk feature.
Not really.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-12-2024 05:46 PM
Message 5 of 18
Hello Chris...
Thanks for the reply,
I can still call out and have just received a call - again, not a Call Safe one. So, same as before on that front as I've mentioned
Clearly then, can't say if there's still a Call Safe problem until I receive a CS call....
Can you tell me exactly what 'change' you made, Chris?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-12-2024 05:32 PM
Message 6 of 18
You must be easily confused then, my friend.
I've mentioned more than once that Call Safe has never given me a problem UP TILL NOW!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-12-2024 07:52 AM
Message 7 of 18
Hi kwilsaint,
I've made a change, could you please retest and let me know if you are still experiencing problems
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 08:42 PM
Message 8 of 18
I'm still confused to be honest. Now you are saying you have never had any problems with CallSafe and you no longer have any issue with your phone service, is that right?
For future reference, you can find more information on how to use a test socket here:
https://community.talktalk.co.uk/t5/Articles/Your-guide-to-main-phone-sockets/ta-p/2205432
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 08:28 PM
Message 9 of 18
Hello Debbie....
First of all my Open Reach Master Socket 5C has an inbuilt micro filter. (see 'ferguson's' reply)
Again, I'm on a Fibre 150 contract with G-Fast Modem connected to my TalkTalk router.
On the front of the 5C are two inputs: for router and phone.
Removing the 5C's plate is simple. The plate incorporates one inbuilt connector which clearly 'handles' both router and phone.
That connector slides into the only available socket to secure the 5C in place.
That's what I thought was meant by 'test socket' (see Michelle's initial reply)
At anyrate, yes I can call out and receive, though so far no more incoming since the last one I mentioned which as I've said was not a 'Call Safe' one.
Therefore, i can only assume the problem either lies solely with Call Safe and/or the line itself as your test 'revealed'
To re-iterate, Debbie: Call Safe has never caused me problems in all the time I've used this excellent TalkTalk feature.
So, over to you - again!
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-12-2024 07:20 AM
Message 10 of 18
Hi kwilsaint
I'm sorry for the confusion.
Just to confirm, you can make and receive calls? The issue is now with call safe?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2024 11:48 PM
Message 11 of 18
It wasn't explicit in Debbie's post, but I think she was expecting you to connect the router at the test socket, you will need a plug in microfilter to do this.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2024 11:22 PM
Message 12 of 18
Staff are not on here before Monday now, @kwilsaint. Sorry about the wait.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 06-12-2024 09:06 PM
Message 13 of 18
Hello Debbie...
Thanks for the contact.
The face plate can be removed, but then what?
If you've already tested the line, why can't you remedy the 'possible fault' detected from your end? I don't see what more I can do.
UPDATE: I received a call yesterday...so clearly I'm receiving and able to send!!
However that call was not a 'Call Safe one' and my original post suggested Call Safe might be the source of the 'possibly found' problem.
At least I can call out and receive, so that's something!
Over to you for any other advice.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-12-2024 07:32 AM
Message 14 of 18
Hi kwilsaint
Is there a removeable face plate on the master socket?
If the cover removes then there should be a test socket underneath this faceplate.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-12-2024 05:34 PM
Message 15 of 18
Hello Michelle...
Thanks for the reply. At least I now know there's a potential gremlin in the works!
Yes, I can call out....
My current contract: Fibre 150 with G-Fast Modem.
I only have ONE socket available: 'Master Socket 5C (Open Reach)' with inputs for G-Fast & Phone.
I have no other sockets, never had, as it happens.
My internet connection is working fine.
I hope this helps...
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-12-2024 07:56 AM
Message 16 of 18
I've run a test on the line now which has detected a potential fault towards the property. Can you make calls ok? Does your main socket also have a test socket please?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-12-2024 08:05 PM
Message 17 of 18
Oh...by the way...I don't use Voice Mail...for reasons I won't bore you with...
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- My 5+ year old faulty router needs replacing...Suggested by online & phone TT tech support. in Fibre
- Emails going to spam in Email
- TalkTalk are unfit to run broadband services in the UK in Fibre
- AVOID TALKTALK: TalkTalk cancelling my transfer to a different broadband provider in Billing
- No full fibre broadband since 28/03/25 in Full Fibre
