Home Phone
No Dial Tone - Landline not working
aircraft
Message 17 of 17
HI,
I have no dial tone on my home phone. My Fibre 35 connection is working normally.
I have run a line test on my phone twice; first time last week. Each time it tells me there is a faultand  I have an open case. However, when I check back the next day, my case appears to have been closed whilst my landline is still not working.
Can you get it fixed for me please?
16 REPLIES 16
Message 1 of 17
That's great, thanks for letting me know 🙂
aircraft
Message 2 of 17
All fixed now. Thanks!
Message 3 of 17
OK thanks for letting me know
Message 4 of 17
Thanks. I have a text from Openreach to say someone is allocated.
The situation is still the same. i.e. Broadband working perfectly but no dial tone.
Message 5 of 17
Line test is now failing with 'disconnection in network' so I've raised this to Openreach as a non-appointed task. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
Message 6 of 17
Hi aircraft,
Apologies, I hadn't seen your PM, I'll book the engineer now and get back to you with the details
aircraft
Message 7 of 17
Could someone from Talktalk respond please?
Message 8 of 17
Thanks for answering the security questions. I've sent you a PM requesting a little more information
aircraft
Message 9 of 17
I have completed the security questions and confirm I accept the engineers charges if necessary.
Message 10 of 17
OK, no problem can you confirm:
aircraft
Message 11 of 17
Chris,
Okay, I have cleared access to the various sockets now. I have also bought a new telephone to try. With the new phone I still have no dial tone and can't make or receive calls. It also doesn't work in the test socket. My broadband is working normally.
So, could you please arrange an engineer visit please. Any day on or after Wednesday, 15th Novemeber would be fine.
Many thanks.
Message 12 of 17
aircraft
Message 13 of 17
Thank you. We'll make some preparations to get access and do some checks to make sure everything looks alright at our end. Then I'll get back to you to arrange for an engineer visit.
Message 14 of 17
OK thanks. To investigate further we'll need to arrange an engineer visit. If you'd like us to do this please let us know and we'll confirm some details with you
aircraft
Message 15 of 17
No I haven't. The wall  plate is in a very inaccessible place.
Instead of a dial tone, I just hear a series of clicks. My current fault reference number is REP-13601375. Can you tell if anyone is looking into it?
Chris-TalkTalk
Message 16 of 17
Hi aircraft,
I've run a line test, it isn't picking up any issues. Have you tested with your telephone connected to your test socket?
