Home Phone
No Dial Tone for the past five days
beclaw69
Message 11 of 11
I haven’t had a dial tone on the landline for the past five days. However when we try and call our number on a mobile you can hear it ring but the actual phone on the landline does not ring. We have tried using another handset but no luck! The line is completely dead and we contacted TalkTalk last week and had no response back.
10 REPLIES 10
Message 1 of 11
Hello beclaw69,
Just checking back in to see if everything is now working ok and if the fault has been resolved?
Message 2 of 11
Hi beclaw69
Openreach have now closed the fault as resolved. Is everything working ok now?
Message 3 of 11
Hi beclaw69
There are no updates from the line engineer as yet but I will keep checking for updates.
Message 4 of 11
Hi beclaw69
I can see that this fault has been assigned to a line engineer this morning. We should hopefully have additional updates from Openreach this afternoon.
Message 5 of 11
Hi beclaw69
I've checked and this fault is still with Openreach, there are no additional updates at the moment.
We will continue to monitor this.
Message 6 of 11
Lovely thank you!
Message 7 of 11
@beclaw69, there's an automatic compensation scheme which applies if the fault is not resolved within a minimum period and is calculated after it is all sorted.
https://community.talktalk.co.uk/t5/Articles/About-your-auto-compensation-credit/ta-p/2326583
Message 8 of 11
Hi beclaw69
Thanks for confirming this.
I have escalated this fault over to Openreach to be investigated by a line engineer and I will continue to monitor for additional updates from Openreach.
Thanks again.
beclaw69
Message 9 of 11
Yes I can confirm, we have tested a corded Unit at the test socket and no luck. We are getting concerned that we are paying for something we are not receiving.
Message 10 of 11
Hi beclaw69
The line test has detected a potential fault. Just to confirm, have you also tried the alternative handset at the test socket?
