Home Phone
No Phone Line/Crackling For Over A Week
Dan2008
Message 8 of 8
Hi.
Have tried different adapters, a different cordless phone, have tried all sockets, master socket and still crackling.
Cannot receive calls either as if our home phone number was to be rung it sais line busy.
Have checked everything inside the house and outside so I gather it possibly could be a problem at the green cabinet box located down the road, can you help please.
7 REPLIES 7
Message 1 of 8
OK, I'll send you a PM to confirm some security info to allow me to progress.
Dan2008
Message 2 of 8
Yes please.
Message 3 of 8
OK, thanks for confirming. Tests are showing a possible loop fault close to or within the property.
A loop fault is either a short circuit or two wires close together or touching,  This can of course be outside on the line itself, degradation of cable insulation due to weathering, but can also be a failure of the wiring within your home, loose wires in one of the sockets, a worn or frayed wire running between the sockets etc.
Openreach are responsible for the line up to and including the master socket. If the fault lies here, then Openreach will repair this.  If the fault is found to be with one of your additional sockets or the wiring to these within the home, then Openreach will charge you for the engineer visit.
With this in mind, would you like to progress to an engineer visit ?
Dan2008
Message 4 of 8
We have 4.
Have tried our cordless phone in them all, and even purchased a new cordless phone and still the same issue.
Yes all others are clear and left Untouched.
Message 5 of 8
Do you only have the one phone socket, or are there other sockets around the home ?  If so, are all other sockets empty ?
Dan2008
Message 6 of 8
No test socket unfortunately.
Message 7 of 8
I'm sorry to hear this. I've run a line test now which has detected a possible loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Does your main socket have a test socket please?
