Home Phone
No dial tone but Internet working OK
niick1
Message 5 of 5
No dial tone at all, been away for a couple of weeks so don't when this happened.
Internet is fine, no problems there.
Checked all connections and connected a brand new corded phone to the master socket, nothing doing.
HELP!
4 REPLIES 4
Message 1 of 5
That's great news.
niick1
Message 2 of 5
All sorted out within the hour, phone line now working as it should.
Thankyou.
Message 3 of 5
Hi @niick1
Tests are showing a loop fault in or near the property.
Does your master socket have a 'Test Socket' ?  If so have you tested at this ?
If not, and you only have one socket, and as you have tested with a new handset with nothing else connected, then an engineer would be required.
If you can confirm, we can then start the booking process with you.
GaryNR32
Message 4 of 5
This is the same as I've been experiencing near Basingstoke.
Gary
