Home Phone
Receive text/SMS on landline for Google Home speaker calls
Hiltophouse
Super Duper Contributor
Message 1 of 1
Google home allows calling on their smart speakers and it also allows you to set Caller ID for these calls. Its fine if you want Caller ID as your mobile but as the speaker is at home for all the family I want the caller ID to be for the home landline.... The problem is I do not recieve the confirmation text on the landline. I historiaclally have received texts on my land line (text to speech) but that does not seem to happen anymore, I also tested sending text from my mobile and that does not come through either.
Any ideas how I can get the confirmation code, i.e. get the text on the landline ?
0 REPLIES 0
