Home Phone
Still no incoming calls
Judithw62
Message 6 of 6
I have been unable to get incoming calls since I moved to TT on 9/7/2025 I have had 3 engineers at my house each giving different stories. I have now been advised by an engineer that it's probably best to cancel my account and open a new one.
5 REPLIES 5
Gliwmaeden2
Message 1 of 6
@Judithw62, do you want staff to actually look into the phone fault?
It sounded as though you were wondering about setting up a new service/reorder, which is why I suggested phoning as staff can't set up contracts.
Do you want staff to investigate the technical fault?
Are you managing to use broadband?
Which package are you on?
Judithw62
Message 2 of 6
I have been trying to speak to the technical department but keep getting cut off
Judithw62
Message 3 of 6
I still dont have any incoming calls
Gliwmaeden2
Message 4 of 6
For reference for staff, I see you opened a thread about the issue also here:
https://community.talktalk.co.uk/t5/Home-Phone/No-incoming-calls/td-p/3119915/page/2
Gliwmaeden2
Message 5 of 6
You'd have to discuss this with the Loyalty team  / Better Value  / Retentions by phoning 03451 720088 or using Chat, @Judithw62.
Full details of opening hours:
Staff on here might be able to advise you about the diagnosis of the phone fault but cannot sort contracts out, and they won't be back on here before Monday.
