Home Phone
VOIP Call Charge .?
Sloopjohnb7620
Message 3 of 3
I currently have a landline which is there simply for incoming calls only. If want to call anyone I’ll use my mobile phone ( either call (Smarty - unlimited calls) or WhatsApp ).
Can anyone tell me if I go for VOIP are calls free or does the charge fall in line with the present landline plan.  The current UK calls boost costs more per month than my entire SMARTY mobile plan.  Any info much appreciated.
johnmcmillan59
Message 1 of 3
'Whatsapp' and 'Line' (VOIP) are free to use on your PC if you already have them on your phone.  You can get rid of the landline, you don't need that for broadband any more.  You'll have to update callers to your landline telephone number to your mobile number.  Landlines are being switched off soon.
Message 2 of 3
TalkTalk VoiP services are chargeable in the same way as landline ones.
