on 02-03-2024 09:15 PM
If the new Internet phone is available,does it mean just plugging into your router or is a new router supplied with a phone socket.
Is a engineer required to change to the service as I have Fibre 65 at the moment?
on 03-03-2024 02:47 PM
Once you get full fibre & assuming that you request Digital Voice at the same time (you can't currently have it added later), then you will probably get the Sagamcom Hub 2. That has a phone port on the back of it to which you can easily connect an ordinary landline phone to or a DECT cordless base station. You do not need to change your phones at all.
on 03-03-2024 02:19 PM
No,just trying to find out what happens i
on 03-03-2024 01:27 PM
Have you been offered an upgrade to full fibre then?
