on 29-09-2023 04:10 PM
Hello everyone
I need to move my phone elsewhere and I've bought a new lead. However when I plug in the new lead the phone rings but you cannot hear anything when you pick it up? It works perfectly once I put the old one in. I am using the D-Link microfilter that comes with the service.
Tia
Lee
on 02-10-2023 09:34 AM
Hi Debbie
I am using a D-Link microfilter from the wall socket and I want to move the phone to another part of the room. I have bought 2 phone cables
Cable 1 is 4 pin on the phone end and the other end to the phone is the smaller 4 pin
Cable 2 is same connection type but 2 pin either end. I've tried both and when they are attached there is no dial tone and it does ring but you cannot hear anyone on the line?
on 02-10-2023 07:01 AM
Hi Renniks
Just to confirm, are you using an extension cable? Have you tried it connected to the test socket?
