Home Phone
buying new cordless 3 handset phone
isanna
Message 2 of 2
need to buy new cordless 3 handset phone which one should i buy with changes on the way.
1 REPLY 1
Message 1 of 2
It doesn't matter, the base station will simply plug into either the Digital Voice Adapter or the back of the Hub 2, depending on the router that you went for.
