on 24-02-2025 07:37 PM
I have had a long running issue with caller display showing withheld number, but recently changed to FTTP including VOIP. I hoped this might sort the problem, and I have at least the table to tick or untick privacy features come back..... Alas, still don't have people's numbers come up and really hoped it would be sorted by now.
on 03-03-2025 02:43 PM
on 27-02-2025 10:56 AM
on 27-02-2025 10:52 AM
Hi Debbie,
I have just taken a call and then phoned from my mobile to double check and delighted to see that both are showing numbers now!
Thankyou very much to you and everyone else who have taken on this problem.
Many thanks
Gavin 😃
on 27-02-2025 08:37 AM
on 27-02-2025 08:29 AM
Hi @armchairgav
I've passed this over to our faults team to take a look and I will post back here as soon as I have further information.
on 26-02-2025 05:33 PM
I've tried different handsets as well, re-setting the router, anything that could possibly constitute a reset from this end.
on 26-02-2025 07:06 AM
Thanks for confirming. Have you also tested with a different handset to rule this out?
on 25-02-2025 06:12 PM
Hi Chris,
Sorry for the delay- yes, caller display is enabled according to My Account, and I have tried the disable and re-enable route to no avail.
on 25-02-2025 08:57 AM
Hi armchairgav,
Just to confirm, is caller display showing enabled in My Account?
