Home Phone
issue with home phone line
wfleckner
Message 10 of 10
We have been having severe crackles on our home phone like for a couple of months now.
This has been reported to talktalk who have sent an engineer out (wall mounted box replaced but problem not resolved) and then an openreach engineer was sent who found no fault at our house.
Talktalk then decided to charge us £75 for the second visit as they said it was not their fault which we have negotiated down to £37.50, not happy about that but we've let it go.
Anyway the openreach engineer said the problem was probably at the main exchange so it's an openreach problem.
Talktalk have closed our case and openreach say we can't contact them direct so we don't know who to contact about this.
I am seriously considering changing provided when our contract ends as I think other providers would be more helpful with this issue.
Has anyone else had a similar problem?
Wendy
9 REPLIES 9
Message 1 of 10
Hi wfleckner,
If you've tested at the test socket with two different telephones and with the router disconnected and you still hear the noise then the only option we have is to arrange another engineer visit. If you'd like us to do this please let us know and we'll confirm some details with you
Message 2 of 10
At the test socket with nothing else plugged in? Sorry to labour the point, but these steps are intended to eliminate as far as possible any issues at your end of the connection.
Message 3 of 10
Yes, that's correct we have tried using a second corded phone.
Message 4 of 10
Hi wfleckner,
Sorry, just to confirm, you've test with a second corded phone at the test socket and still hear the noise on the line?
Message 5 of 10
Hi Michelle,
Yes I can confirm the noise is still present with an alternate phone directly connected with no other equipment attached.
We don't feel the need for another engineer to attend, we have already had 2 engineers visit the property, the second one (openreach engineer) could find no issues at our end. We are unwilling to pay any more money to TalkTalk for engineer visits.
We were told by the openreach engineer that the fault was likely at the exchange end but we don't seem to have any way of contacting openreach direct to discuss this problem.
As I have indicated before if we do not get this resolved soon we will be looking at changing our provider when our contract ends to see if they can get our landline issue resolved.
We have now had an issue for over 2 months now and the landline is almost unusable.
Message 6 of 10
Morning Wendy,
If the noise is still present at the test socket (behind the faceplate) with 2 different phones and with all other equipment removed from the line then the next step would be to arrange an engineer visit to the property.
If you'd like to go ahead with this then please can you confirm acceptance of possible time related engineer charges and also provide a few days availability AM (8-1) and PM (1-6) and we can arrange this visit for you.
Message 7 of 10
Sorry I thought I had replied to this.
The noise is generally there although there can be some times when it doesn't happen so much.
We have done all the tests you have suggested.
Is there any way we can escalate this? It seems that if we raise another call with TalkTalk they will just arrange for another engineer to visit, find no issues and charge us for the privilege.
I can't find anyway to contact OpenReach direct.
If this carry's on we will have to look at changing suppliers when contract ends and hopefully the next one will be more helpful fixing our problem.
Wendy
Message 8 of 10
Hi @wfleckner
I've completed 2 different line tests and both of these tests are clear - no line faults detected.
Is the noise there on every call?
Can I just check, you have tested with a different phone (if possible corded) directly at the test socket, with the router removed?
Message 9 of 10
If an Openreach engineer said there was no fault found internally, but maybe at the exchange, why did they not follow that up? Seems odd.
Anyway, this has been flagged up to the support team here, wait for a response from them.
