Home Phone
move phone from router to lounge
19CHRIS54
Message 3 of 3
I have full fibre with voice. I want to move the phone away from the Router to a different room. Is there a piece 'kit' that enables/supports  this? I believe BT have some such ability but have discovered nothing re Talktalk
Message 1 of 3
Hi there @ferguson Thanks for the support:)
Message 2 of 3
No. You can either get a suitable length of cable, or use multiple cordless handsets.
