Home Phone
phone line constantly engaged
davelunson
Message 5 of 5
And internet has gone down - help
D Lunson
4 REPLIES 4
Message 1 of 5
@davelunson, renewals are best discussed over the phone on 03451 720088 or using Chat  - usually better deals than anything by email  / my account.
Can't be done through the forum support team.
Message 2 of 5
Hi Dave,
Thanks for updating your profile. Are you a Shell migration customer? If you are then there's dedicated team (Shell migration team) that will be able to help, you can contact them on - 0345 172 0088
davelunson
Message 3 of 5
Updated - All that is required to get back on line is a phone
line check as I think fault with BT. Perhaps you could organise
otherwise I will have to go to another provider as I am
out of contract. Leave with you to sort asap pleasr. Perhaps
some renewal terms would also be a  good idea.
D Lunson
Message 4 of 5
Hi dave,
  • Name
  • Telephone number or Account number
  • Alternative contact number
