Mobile support
For any questions about your TalkTalk mobile service.
Pixel email issues
WINGNUT1972
Message 13 of 13
Does anyone know how to add talk talk mail to a Google pixel ? driving me daft .
12 REPLIES 12
Message 1 of 13
Good to know you got there.
I appreciate your time to let me know. Thank you.
WINGNUT1972
Message 2 of 13
Tried multiple times today , and just had success. Thanks for your help
Message 3 of 13
and...
WINGNUT1972
Message 4 of 13
Password is strong
Message 5 of 13
And... the password strength?
And the Gmail app screenshots?
WINGNUT1972
Message 6 of 13
Already tried , logs in no problem .
Message 7 of 13
Check via TalkTalk Mail webmail that you can login with the email password.
Select here: Sign in to TalkTalk Mail
Enter your full TalkTalk Mail email address, select Continue and enter the password, select Sign in.
Do you get signed in? Is the password strong enough? A weak password may not be authenticated when you try to set up an email app. Passwords must be a minimum of 8 characters. I recommend 12 - 15 multicase letters, numbers and at least one approved symbol.
Screenshot the incoming and outgoing server settings, image edit to remove the first part of your email address from view and upload here using the picture icon above this Reply area. I'll take a look.
WINGNUT1972
Message 8 of 13
I've tried this numerous times tonight , hasn't worked .
Message 9 of 13
The phone will need to have a Wi-Fi connection to the Internet to verify the Incoming and outgoing server settings.
  • Via Passwords & Accounts you'll have selected Add an account
  • Select Personal (IMAP)
  • Enter the TalkTalk Mail address and Password
  • Tap NEXT
Have you got to the point of entering the Incoming Server settings?
  • Username: Full TalkTalk Mail email address
  • Password: TalkTalk Mail password
  • Server: mail.talktalk.net
  • Port: 993
  • Security Type: SSL/TLS
And the Outgoing Server settings?
  • Require sign in: ON
  • Server: smtp.talktalk.net
  • Port: 587
  • Security Type: STARTTLS
Do let us know if that gets you access to your TalkTalk mailbox.
WINGNUT1972
Message 10 of 13
Yes keeps saying can't connect to server
WINGNUT1972
Message 11 of 13
Yes , new phone , keeps saying can't connect to server .
Gondola
Message 12 of 13
To the Gmail email app?
