Online security
Get answers and information about our security products.
Forgot parental control password
23791Spider
Message 4 of 4
I have forgotten my parental control passwod. How do I reset it without knowing the old password?
3 REPLIES 3
Message 1 of 4
Go into settings and select device settings then factory reset.
Message 2 of 4
I have tried 0000 and 1234 but its doesn't work. How do I reset the box?
Message 3 of 4
Is this on the TV Hub?
Unless you set your own password the default is either 0000 or 1234.
Otherwise you will need to reset the box.
