Online security
Get answers and information about our security products.
Scam Protection & Security settings
KJC2561
Message 6 of 6
I am not able to get into my security and change settings, it now just keeps going round trying to sell me SuperSafe and telling me to download the Eero App to manage security. I have downloaded the App and it still wont allow me to make security changes on.
I used to do this easily on the TalkTalk website in My security.
5 REPLIES 5
Billx
Message 1 of 6
Can any of the TalkTalk Full Fibre 150, 500 or 900 which are normally eero-enabled packages, be set to eero-disabled?
Bill
Message 2 of 6
Hi KJC2561
I can give you the answer as it's very straightforward.
If your TalkTalk package is Full Fibre 150, 500 or 900 and is an eero enabled package with eero 6 or eero pro 6 provided free-issue by TalkTalk then that package will be supported with eero Secure instead of TalkTalk HomeSafe.
The eero Secure Advanced Network Security on eero enabled packages operates at a network level via the TalkTalk DNS servers. It is important that the TalkTalk DNS is set as the default DNS in order to be assured that your network connection is protected from viruses, malware, phishing attacks and other malicious downloads etc.
TalkTalk eero enabled packages do not work with HomeSafe and cannot select HomeSafe in place of eero Secure. On non-eero enabled packages then HomeSafe, including Scam Protection blocking of potentially malicious remote access software, is available via the TalkTalk DNS servers.
The eero Support Hub is your go-to resource for information, guides and Community support
Select here:
eero Support Hub
eero 6 and eero Pro 6 Help
eero - Setting up your eero
 eero app
 Using eero advanced features
eero Secure
eero Secure - Blocking or Allowing websites
eero Secure - Managing your content filters
Message 3 of 6
Ady
I have always used Homesafe whilst having Eero before so what is the problem?
Are you saying that I have no security now?
It also states on your website
HOMESAFE
Our web filter is included for your home network, protecting any device that’s connected.
So please explain what has changed and why?
Please answer
Do I or do I not have Scam protection with TalkTalk?
KJC2561
Message 4 of 6
Ady
HOMESAFE
Please answer
Ady-TalkTalk
Message 5 of 6
Hi KJC2561, when using Eero you can't use HomeSafe or Supersafe anymore. Have you tried removing and reinstalling the Eero app?
Ady
