Online security
Get answers and information about our security products.
SuperSafe Failed installation
VicF47
Chat Champion
Message 4 of 4
Windows 7 Home Premium Edition + SP1: Intel Core i5 processor
"MyAccount" shows "SuperSafe" activated with several licenses including Windows 7 laptop.
Laptop shut-down and unused for a couple of weeks while away from home.  On re-starting Banking Protection sent a warning message and TT 'Online Defence' would not start or update. Tried several times. FAQs suggested uninstalling and starting again, so tried it.
Downloaded the installer but when I tried to run it I got the message that my device was not compatible.  Tried to run the old installer (downloaded November 2019) but after the first 'welcome' screen, again I got the message that device was not compatible.
Is there anything I can do to resolve the issue?
NB:  SuperSafe seems to be working fine on my Windows 10 desktop PC
3 REPLIES 3
Message 1 of 4
Hi Ady and Divsec,
Thanks for your comments.
Pretty much as I thought.  I've been putting it off for a while.  Unfortunately the laptop is now 13 years old and when I checked about upgrading to Windows 10 a year or three back it said "device was not suitable", so I need to splash out on new tech.
However, Supersafe system requirements still says Window 7 is OK!  Time for an edit of the FAQs I think
Vic
Ady-TalkTalk
Message 2 of 4
Hi VicF47, Divsec has hit the nail on the head. Windows 7 is no longer supported by Microsoft and as a result can't be supported by others.
Ady
Divsec
Message 3 of 4
Hi @VicF47 I think you might need to bite the bullet and upgrade from Windows 7.
Windows 7 has not been supported by Microsoft for quite some time now.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
