Get answers and information about our security products.
on 14-05-2025 09:47 AM
We subscribe to a website that sends us several links a day by email which we need to complete certain tasks. They use Convertkit to send these emails. This last week these links have become inoperable on any device (laptop, phone, ipad, pc) while connected to our Talktalk router (the phone worked only while disconnected from the router). As it is an issue on all our devices while connected to the router the problem is not with the individual devices or their caches. Not all the devices use security software like Norton, so that is also not the reason. We have reset the router to factory settings, but that didn't make any difference.
ChatGPT tells us that Talktalk does indeed block sites like Convertkit. Is there any way Talktalk can undo this block? If so, how can we make them do it?
on 06-06-2025 05:52 PM
Hi there @Martina2B .TalkTalk reserves the right to block any site or link that is not deemed fit or goes against policies on our TalkTalk network. If you still require access this site please use a different network connection or your mobile data, thanks.
on 06-06-2025 05:24 PM
We reported your finding to the original website who were sending us these links via "Convertkit" ( now known as "Kit"). They responded with "We can find no evidence of the court order you refer to".
Would you please specify and substantiate your claim.
Looking forward to hearing from you.
on 20-05-2025 08:08 AM
This website has been taken down (blocked) by a court order for legal reasons.
Unfortunately, TalkTalk is unable to assist with this matter
on 19-05-2025 06:02 PM
No, it is on all devices ( various users) only when connected to our router. Only one
pc has an adblocker. My phone is without ad blocker, and gets the blocking message when on wifi, but gets the link to work when on the mobile network, which is not Talktalk
on 19-05-2025 05:43 PM
Please confirm if the issue was caused by your Ad-Blocker?
on 19-05-2025 05:31 PM
Yes, it is a ConvertKit message saying "This site can't be reached"
As you can see earlier in the chat, quite a few links via ConvertKit get blocked.
Hopefully you can get more info from that link I posted here.
on 19-05-2025 04:59 PM
Okay, noted. Do you see a blocked webpage notification message when attempting to access the site you experience problems with?
on 19-05-2025 04:57 PM
No, but I did have my talktalk line checked thoroughly two weeks ago, when I addressed all this with someone via webchat. They did not find any issues with the line.
on 19-05-2025 03:36 PM
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 19-05-2025 03:21 PM
Yes, I am here
on 19-05-2025 08:25 AM
Hi there @Martina2B, I will into this for you. Please confirm if you are at home at the moment?
on 17-05-2025 02:45 PM
@Martina2B, staff will follow after the weekend.
on 17-05-2025 10:17 AM
Yes, just about 10 to 14 days ago.
on 16-05-2025 08:21 AM
Hi there you did mention that this issue started recently correct?
on 16-05-2025 07:55 AM
Hi Fez, I am at home now. Thanks.
on 15-05-2025 12:19 PM
Thank you. Please kindly confirm if you are currently home right where the services are installed?
Fez.
on 15-05-2025 12:07 PM
Hi, yes, it is every link that is being sent via ConvertKit. the original website, who uses ConvertKit for a number of links, also sends some links direct and they all work. Only the links they send through ConvertKit are blocked.
on 15-05-2025 10:04 AM
I understand how frustrating this can be, and I'm here to help you.
It appears that there may be a block on ConvertKit or related sites from our network, which is why you're unable to access those links on your devices, but we will have a look into this. Are you having issues with every link you try or just certain links?
Fez.
on 15-05-2025 09:43 AM
Yes, we are. We would still like to get to the bottom of this. Is there any way you can check if the website Convertkit is on some blocklist by Talktalk?
on 15-05-2025 08:17 AM
Hi there @Martina2B , thank you for providing us with an update regarding this issue. Just to check, are you still experiencing these issues even with the changes made?
-Fez.
