Online security
Get answers and information about our security products.
supersafe error message and constantly asking to restart!
sdwood
Message 10 of 10
supersafe has suddenly started showing an error message and asking to restart every 5 mins. I've uninstalled and re-installed with no difference. Soent over 1 hour on chat with TT but not resloved the issue just keep sending me back to help page.
9 REPLIES 9
Message 1 of 10
@GaynorB5
Please do not post on other people's threads.
Please start your own thread.
Thank you
GaynorB5
Message 2 of 10
I am having the same problem!!  Started happened a few days ago, restarted PC many times, the message doesn't reappear for about 24 hours.  Not happy as it says my PC is not protected!!
Message 3 of 10
@pcOLDkid21
Please start your own thread as each case is considered unique and it is easier for support to be given to one person per thread and also less confusing.
To start your thread click the Browse button, then Help With Your Service and select the appropriate category. You will then see a Blue Button "Start A Topic"
Please also note that you should only post back on that thread and not start another on the same topic as multiple posts cause delay to you and others seeking help.
Thank you
pcOLDkid21
Message 4 of 10
I am having a similar problem with Supersafe.  It keeps telling me a file is missing.  How do you correct it.
Message 5 of 10
Hi there @sdwood please share a screenshot of the error message.
Phili
sdwood
Message 6 of 10
Yes I did. I even re-installed windows 11 to get a clean start. Every time my computer reboots up pops the supersafe asking me to restart my computer. This is getting very annoying and I'm seriously thinking about changing my supplier. It works fine on my laptop but not on my home computer.
Message 7 of 10
Can you confirm the device this is occuring on please?
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
sdwood
Message 8 of 10
 I did that - no joy
Message 9 of 10
Did you use the f-secure uninstallation tool, as other uninstall programmes often leave parts behind.
Try uninstalling using this, then reinstall and this should clear the issue.
https://www.f-secure.com/en/support/tools
Let us know how you get on
