on 14-08-2024 04:31 PM
I have pressed accessabilty button on remote but cannot find how to get out.
Answered! Go to Solution.
on 14-08-2024 04:39 PM
You use the back button, normally an arrow on a "curved" line.
If you are using the hub and pressed another button, you may find the settings bar is now stuck, in which case turn off at the mains and restart your box.
