Being disconnected watching tv every 10 minutes
ChristoffBas
Whizz Kid
Message 32 of 32
Hi, since last week, my router is  rebooting while watching tv. The amber light starts flashing and I then lose connection. Very frustrating! I have switched off for 5 minutes, but still get the same issue.
I recently received correspondence to say my router was no longer supported by yourselves, so can you please send me a replacement one which is.
Thanks very much
31 REPLIES 31
Message 21 of 32
It is literally just the router which keeps flashing to amber and losing connection, while it reboots. I have only noticed it while watching TV at the moment.
Message 22 of 32
No worries, as I am running tests I will need you to answer some questions for me Chris:)
Does the problem occur everywhere you try and use the WiFi, or just in certain parts of the house - for example upstairs, or outside the house?
Message 23 of 32
Yes they will as we will use our mobiles.
Can you keep me updated please with your tests.
Message 24 of 32
Openreach has a dedicated team to deal with vulnerable customers, and these are identified as Emergency Welfare Cases. An Emergency Welfare Case is where the customer has a life-threatening illness and applies to repair cases that have a total loss of service In-life or in a provisioned state that requires the urgent restoration of service.
Will you (and anyone who lives with you) be able to contact emergency services while your services remain impacted?
Message 25 of 32
No I don't.
nambuso-TT
Message 26 of 32
No worries, we will get to the bottom of this:)
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Message 27 of 32
Yes, please run the tests and let me know.
Thanks very much
Message 28 of 32
Thank you very much for confirming, I will need to run checks for you to determine the cause of the issue, just to confirm as you did mention in your original message that the amber light starts flashing and you  then lose connection, you can say that you are experiencing dropping connection so that I can run relevant tests to your issue?
nambuso-TT
Message 29 of 32
Message 30 of 32
Hi, thanks - yes I am messaging from home where the TalkTalk services are installed.
ChristoffBas
nambuso-TT
Message 31 of 32
Hi there ChristoffBas. I am very sorry to hear this. I will look into this for you. Please confirm if you are messaging us from home, where the TalkTalk services are installed. Thanks
