3 hours ago
There last few weeks catch up is not working on channel 4
29 minutes ago
This article may help regarding resetting your box.
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
37 minutes ago
Unfortunately this is a known issue that is caused by the adverts and programmes being held on different servers and the switch back from adverts does not work properly.
This can also affect MY5 at times. This is no a fault with the box but the ALL4 app, and can affect different devices at different times. Fixing the app for one device can have a knock on effect to other devices.
You haven't said which box you have but resets do sometimes work by downloading the apps again which can clear this bug, but not always.
If it persists you would be best reporting it to the app owner, in this case C4, so they can look into this. Your box is only the delivery method for the app and therefore TalkTalk are not responsible for this.
Hope a reset helps, but if you are unsure on how to do this, please let us know which box you have.
Thank you.
3 hours ago
When I put catch up on channel 4 it works fine until the first advert then it freezes and won't move on at all
3 hours ago
Which box do you have so we can offer the correct advice please?
What symptoms are you experiencing when you try to play a programme or can you not access at all?
What have you tried, if anything, to rectify the issue?
If you can let us know we can then offer advice.
Thank you.
