Error Message when trying to turn TV on
jdm79
Message 4 of 4
This is probably a really stupid question but, yonight, trying to switch on my TV all I get is "Weak or No Signal  Check the antenna cable connection"
I have checked the cables, all seems normal. What now?
3 REPLIES 3
amahle-TT
Message 1 of 4
Hi there @jdm79, please do confirm. Thanks @fr8ys.
Message 2 of 4
Do you get the normal picture on the TV if you plug the aerial directly into the TV bypassing the box?
Is it all stations or just some? HD stations are more prone to fluctuations than SD ones.
If not you may have a damaged cable or aerial,bot you signal my be compromised . Check you local transmission by looking on Freeview website or digital TV site to see if there is any work going on on your transmitter
It could just be atmospherics which would normally clear in 24 to 48 hours, but if it persists then you could try a retune, but you could lose any stations you currently have.
If it's an aerial issue you will need to consult a local installer for a solution
In case it's the box, what model do you have?
jdm79
Message 3 of 4
I checked all the cables and seemed all OK. As a "what if" I tried an alernative HDMI cable. Yay, all now working!!
