Fire stick
Woo66
Message 2 of 2
Hi. I’ve just started using talk talk tv today. I use a fire stick and when using that today , I cannot get back to tv on my talk talk. I’ve even tried removing the fire stick and still can’t get my tv back on ? Thanks
1 REPLY 1
Message 1 of 2
From your comments I assume you have the TV Hub and the following is based on this.
I also assume that the firestick and Hub are connected to your TV via their own HDMI TV input.
If so, then you should be able to switch between them using the source button, usually and arrow inside a rectangle, on the TV remote, and selecting the appropriate HDMI input.
If I have misunderstood what the issue is, could you please confirm your setup and what the issue is in more detail please
Thank you.
