Limited channels
MedinaDream
Message 3 of 3
Hi, I've just set up my TV and cannot get any channels other than the ones with my now entertainment package. I need all the normal ones, BBC, ITV, Channel 4 etc. I don't have an aerial.
Any help would be really appreciated.
Many thank in advance
Message 1 of 3
You need an aerial the box will not work otherwise as it uses the Freeview channels.
Also some catch-up apps such as ITVX need an aerial connection to confirm the region.
Message 2 of 3
Sorry, but you're going to need an aerial. Were you not using terrestrial TV before?
