Locked TV channels
Jessmark
Message 2 of 2
Hi how can you unlock TV channels on your talk talk box? Thank you in advance.
1 REPLY 1
Message 1 of 2
Depends on which box you have.
YouView, go to settings, TV channels, then unhide all channels.
If you are talking adult channels go to settings, restrict then you may need to put your pin in to change
